Einleitung
This guide shows how to replace the USB 3.0 port on the Lenovo Yoga 920-13IKB.
Was du brauchst
Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
Slide the iFixit Opening Tool under the back cover to lift it up.
Pull up on the cover with your hand to release the tab holding the center of the cover in place.
Disconnect the red and black wire connected to the speaker using the iFixit Tweezers.
Lift up the black tab on the flat cable connector with the iFixit Opening Tool.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Just wanted to say thank you to Alyssa and the others who contributed to this.
I just used your guide to fix a problem with my Yoga constantly entering and waking (repeatedly, seconds apart) from connected sleep mode. Infuriating. It was accompanied by the USB connect/disconnect sound as well.
Using the Event Viewer I managed to find out it was entering sleep mode in response to the power button (which I wasn’t pressing). So, I used your guide to disconnect and reconnect the USB board and it has resolved my issue.
iFixIt gained some tools income, you gained some more reputation points, and I gained a laptop that’s behaving itself now!
Now, what else can I break? ;o)
