Was du brauchst
Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
Pry off the back cover using the plastic opening tool.
Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
Use a plastic opening tool to remove the two small, white power cable connectors for each of the two fans.
To reassemble your device, follow these instructions in reverse order. Remember to apply fresh thermal paste to the heatsink during reassembly.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
