Zum Hauptinhalt wechseln
Lenovo Yoga Tab 3 10 Wifi Module Replacement
Was du brauchst
  1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 2, Bild 3 von 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 3, Bild 1 von 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 3, Bild 2 von 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 3, Bild 3 von 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: Schritt 4, Bild 1 von 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: Schritt 4, Bild 2 von 2
    • Use the nylon spudger to gently lift the foil cover of the wifi model.
  5. Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to gently lift the gold tape located above the copper foil.
  6. Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic spudger to disconnect the wifi module connector from the motherboard.
  7. Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 7, Bild 1 von 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift the wifi module from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Phanudej
1.190 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S3-G2, Sullivan Spring 2017 Mitglied von USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
where can i buy this type of module?
rebeca rackolavsci - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 37
Insgesamt: 3,731
