Zum Hauptinhalt wechseln
Lenovo Yoga Tab 3 8 Back Cover Replacement
Was du brauchst
  1. Lenovo Yoga Tab 3 8 Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo Yoga Tab 3 8 Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo Yoga Tab 3 8 Back Cover Replacement, Back Cover: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Back Cover Replacement: Schritt 3, Bild 1 von 3 Lenovo Yoga Tab 3 8 Back Cover Replacement: Schritt 3, Bild 2 von 3 Lenovo Yoga Tab 3 8 Back Cover Replacement: Schritt 3, Bild 3 von 3
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Nicklaus Krems
1.067 Reputation
8 Anleitungen geschrieben
USF Tampa, Team S16-G2, Eyestone Fall 2017 Mitglied von USF Tampa, Team S16-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S16G2
4 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
Had put the SIM in the Memory card slot, instructions came in handy.
Brijesh Rajashekara - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 37
Insgesamt: 2,975
