Zum Hauptinhalt wechseln
Lenovo Yoga Tablet 10 Headphone Jack Replacement
Was du brauchst
  1. Lenovo Yoga Tablet 10 Headphone Jack Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 3, Bild 1 von 2 Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Headphone Jack Replacement, Headphone Jack: Schritt 4, Bild 1 von 2 Lenovo Yoga Tablet 10 Headphone Jack Replacement, Headphone Jack: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the headphone jack cover with tweezers by grabbing it and pulling directly up and away from the device.
  5. Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 5, Bild 1 von 3 Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 5, Bild 2 von 3 Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 5, Bild 3 von 3
    • Remove the two 3.5mm screws using the Phillips #00 Screwdriver.
  6. Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 6, Bild 1 von 3 Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 6, Bild 2 von 3 Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the headphone jack from the motherboard by placing the spudger in between the connections and motherboard and pushing up towards you.
    • Pull the wire towards the headphone jack to disconnect it.
  7. Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 7, Bild 1 von 2 Lenovo Yoga Tablet 10 Headphone Jack Replacement: Schritt 7, Bild 2 von 2
    • Use tweezers to remove the headphone jack by pulling it up and towards you.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mahima
234 Reputation
1 Anleitung geschrieben
Cal Poly, Team S2-G6, White Winter 2019 Mitglied von Cal Poly, Team S2-G6, White Winter 2019
CPSU-WHITE-W19S2G6
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 735
