Einleitung
Before you proceed with this guide, you should know how to remove the back cover.
Was du brauchst
Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
Disconnect the headphone jack from the motherboard by placing the spudger in between the connections and motherboard and pushing up towards you.
Pull the wire towards the headphone jack to disconnect it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
