Zum Hauptinhalt wechseln
Lenovo Yoga Tablet 2 830-F Antenna Replacement
Was du brauchst
  1. Lenovo Yoga Tablet 2 830-F Antenna  Replacement, Wifi Antenna: Schritt 1, Bild 1 von 2 Lenovo Yoga Tablet 2 830-F Antenna  Replacement, Wifi Antenna: Schritt 1, Bild 2 von 2
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Antenna  Replacement: Schritt 2, Bild 1 von 3 Lenovo Yoga Tablet 2 830-F Antenna  Replacement: Schritt 2, Bild 2 von 3 Lenovo Yoga Tablet 2 830-F Antenna  Replacement: Schritt 2, Bild 3 von 3
    • Remove the six screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the three screws on the back of the secondary board with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components.
    • Remove the ZIF connectors connecting the boards to the other electrical components.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Antenna  Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the antenna module from the motherboard.
Abschluss
Mario Gjyli
449 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S2-G4, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 952
