Was du brauchst
Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
Using the Phillips Screwdriver #00 bit remove the 6 screws.
Using the Phillips Screwdriver #00 bit remove the 3 screws.
After removing all the screws, disconnect the ribbon cables.
Disconnect the ZIF connectors.
After removing the motherboard and antennas the camera module is located on the right as marked in red.
Remove the three 2mm screws holding the module in place with the Phillips Screwdriver #00 bit.
Eine weitere Person hat diese Anleitung absolviert.
