Einleitung
This guide will walk you through the process of removing and replacing a damaged display on your Lenovo Yoga Tablet 2 830-F, ensuring each step is handled carefully to avoid any further damage.
Was du brauchst
Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
Remove the six screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
Remove the three screws on the back of the secondary board with the Phillips Screwdriver #00 bit.
Remove the ribbon cables connecting the boards to the other electrical components
Remove the three 2mm screws on the back of the left speaker module with the Phillips Screwdriver #00 bit.
Remove the three 2mm screws on the back of the right speaker module.
Use the opening tool to pry the battery compartment off the right hand side of the back.
Well done on replacing your tablet's display! Reassemble your device by following these instructions backwards, ensuring all parts are correctly aligned and secure. Enjoy your refreshed Lenovo Yoga Tablet!
4 weitere Personen haben diese Anleitung absolviert.
