Zum Hauptinhalt wechseln
Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement
Was du brauchst
  1. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 2 Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 2 von 2
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw with a Phillips #00 bit.
    • Using the blue opening tool or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 2mm screws on the back of the left speaker module with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the left speaker module.
    • Replace the old left speaker module with the new left speaker module.
    • Be careful not to damage the ribbon cables on the new left speaker module while reassembling the device.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S2-G4, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Mitglieder
13 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 24
Insgesamt: 2,070
