Einleitung
This guide will show you how to remove the SSD of the Lenovo Yoga 3 Pro. As an extra precaution, the battery should be removed first before proceeding with the rest of the device.
Was du brauchst
Flip the laptop so that the back panel is facing up.
Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
