Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. 3 Phillips screws are located under the battery cover, unscrew them
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. The mouse cover at the bottom should move freely but at the top is hold by 2 brackets In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Du brauchst kein Neues.
    Take $10 off $50 with
    SKIPANDSAVE10
    Jetzt speichern
    SKIPANDSAVE10
    Jetzt speichern
  4. At this point, you have separated the mouse cover At this point, you have separated the mouse cover
    • At this point, you have separated the mouse cover
  5. Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  6. The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter When you reassemble the mouse, make sure you don't crush the power cable
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Shinn Chyang Chen
2.284 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 34
Insgesamt: 3,079
