Was du brauchst
The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
2 weitere Nutzer:innen haben diese Anleitung absolviert.
