Einleitung
Whether you broke a string or want a freshly bright sound for your guitar, this guide will teach you how to replace a string on your Epiphone Les Paul electric guitar. I will be using D'Addario Super Light Gauge strings.
Was du brauchst
Loosen the first sting you would like to replace by turning the corresponding knob counter-clockwise.
Pull string away from the rest of the strings and snip it with the wire cutters.
Remove the cut string from the bridge of the guitar and its corresponding spoke.
Lead new string through bridge and then spoke. Leave plenty of slack in the string.
Use your right hand to hold the slack near the bridge, and use your left hand to tightly pull the string through the spoke while turning the knob with the fingers of your left hand.
Once the string starts getting tight and your right hand is no longer needed to hold slack, start tuning the string to the note you want it at.
Have fun playing with your new bright-sounding guitar.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
