Zum Hauptinhalt wechseln
Les Paul Wireless Guitar Battery Pack Replacement
Was du brauchst
  1. Les Paul Wireless Guitar Battery Pack Replacement, Les Paul Wireless Guitar Body Teardown: Schritt 1, Bild 1 von 1
    • Remove batteries
  2. Les Paul Wireless Guitar Battery Pack Replacement: Schritt 2, Bild 1 von 2 Les Paul Wireless Guitar Battery Pack Replacement: Schritt 2, Bild 2 von 2
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Battery Pack Replacement: Schritt 3, Bild 1 von 3 Les Paul Wireless Guitar Battery Pack Replacement: Schritt 3, Bild 2 von 3 Les Paul Wireless Guitar Battery Pack Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: Schritt 4, Bild 1 von 2 Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: Schritt 4, Bild 2 von 2
    • Gently move the capacitor around until it breaks off
  5. Les Paul Wireless Guitar Battery Pack Replacement: Schritt 5, Bild 1 von 1
    • Solder on the new capacitor.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Chris
881 Reputation
6 Anleitungen geschrieben
2 Kommentare
What cap is needed?
Martin Samuelsson - Antwort
Mine is: 2200uF 10V
Thijs van Ulden -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 28
Letzte 30 Tage: 92
Insgesamt: 12,245
