Einleitung
This guide will demonstrate how to open the neck of the guitar and replace the fret buttons, the colored buttons on the neck that correspond to the notes in the game.
Was du brauchst
Pull the Lock on the back of the body to detach the neck from the body.
Remove the 10 screws (each are 1 cm long) on the back of the neck using a T-10 Torx security screwdriver.
Remove the back of the neck.
Unscrew the two screws on the fret PCB using a PH1 Phillips head screwdriver. Each screw is 0.8 cm.
Remove the fret PCB
6 weitere Personen haben diese Anleitung absolviert.
