Einleitung
The adapter connects the power chord to the printer.
  1. Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
    • Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
    • Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
  4. Firmly push adapter in until you hear a click.
    • Firmly push adapter in until you hear a click.
Abschluss
The adapter should be securely inserted into the back end of the printer and be ready for use.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Raymond
42 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 18-38, Regan Winter 2013 Mitglied von Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Mitglieder
9 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 706
