Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The duplex unit allows the printer to print on the front and back of a page without having to manually flip over the paper.
  1. Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
    • Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
  2. Remove the duplex unit from the back of the printer with the duplex unit facing up. Remove the duplex unit from the back of the printer with the duplex unit facing up.
    • Remove the duplex unit from the back of the printer with the duplex unit facing up.
Abschluss
Once the duplex unit is installed, your printer will be able to print on the front and back of pages.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Raymond
42 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 18-38, Regan Winter 2013 Mitglied von Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Mitglieder
4 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 738
