Zum Hauptinhalt wechseln
Lexmark Intuition S505 Ink Cartridges Replacement
  1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: Schritt 1, Bild 1 von 2 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: Schritt 1, Bild 2 von 2
    • Lift the scanning unit, exposing the print head.
  2. Lexmark Intuition S505 Ink Cartridges Replacement: Schritt 2, Bild 1 von 1
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
  3. Lexmark Intuition S505 Ink Cartridges Replacement: Schritt 3, Bild 1 von 1
    • Lift the frame to expose the ink cartridges.
  4. Lexmark Intuition S505 Ink Cartridges Replacement: Schritt 4, Bild 1 von 1
    • Push the button located above the designated ink cartridge until it pops out.
  5. Lexmark Intuition S505 Ink Cartridges Replacement: Schritt 5, Bild 1 von 1
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
  6. Lexmark Intuition S505 Ink Cartridges Replacement: Schritt 6, Bild 1 von 2 Lexmark Intuition S505 Ink Cartridges Replacement: Schritt 6, Bild 2 von 2
    • Close the scanner unit.
Abschluss
Once your ink cartridges are in place, your printer should now print high-quality documents.
2 weitere Personen haben diese Anleitung absolviert.
Omar
111 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 18-38, Regan Winter 2013 Mitglied von Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 3,270
