Zum Hauptinhalt wechseln
Einleitung
The scanner unit allows users to scan copies.
  1. Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
    • Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
  2. Remove the duplex unit from the back of the printer with the duplex unit facing up. Remove the duplex unit from the back of the printer with the duplex unit facing up.
    • Remove the duplex unit from the back of the printer with the duplex unit facing up.
  3. Locate the two screw holes that connect the two cylindrical extensions from the top portion of the scanner unit to the printer.
    • Locate the two screw holes that connect the two cylindrical extensions from the top portion of the scanner unit to the printer.
  4. Unscrew the two size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
    • Unscrew the two size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
  5. Raise and close the scanner unit to observe that the hinges lock in place when lifted.
    • Raise and close the scanner unit to observe that the hinges lock in place when lifted.
  6. Laptop-Akkus
    Wenig Aufwand, große Wirkung.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  7. Firmly press the hinges inward toward the middle of the printer on both sides at the same time. The hinges should be easily lifted up and removed. Firmly press the hinges inward toward the middle of the printer on both sides at the same time. The hinges should be easily lifted up and removed.
    • Firmly press the hinges inward toward the middle of the printer on both sides at the same time. The hinges should be easily lifted up and removed.
  8. Locate the three screws connecting the plastic tray to the printer.
    • Locate the three screws connecting the plastic tray to the printer.
  9. Remove the three size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
    • Remove the three size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
  10. Remove the plastic cover by unlocking the plastic hinges at the inside edges of the printer. Use a plastic opening tool or a tweezer to slowly move in between the crease around the printer to unlock it.
    • Remove the plastic cover by unlocking the plastic hinges at the inside edges of the printer. Use a plastic opening tool or a tweezer to slowly move in between the crease around the printer to unlock it.
  11. Slowly raise, but do not remove the plastic cover with the scanner unit so that it exposes the three cables connecting the scanner unit to the printer. Slowly raise, but do not remove the plastic cover with the scanner unit so that it exposes the three cables connecting the scanner unit to the printer.
    • Slowly raise, but do not remove the plastic cover with the scanner unit so that it exposes the three cables connecting the scanner unit to the printer.
  12. Carefully unplug the pink cable.
    • Carefully unplug the pink cable.
  13. Carefully unplug the gray data cable.
    • Carefully unplug the gray data cable.
  14. Carefully unplug the white ribbon data cable.
    • Carefully unplug the white ribbon data cable.
  15. Locate the three ports for the cables from the scanner unit and make sure they are unplugged.
    • Locate the three ports for the cables from the scanner unit and make sure they are unplugged.
  16. Remove the scanner unit with the plastic cover by lifting it up from the bottom portion of the printer.
    • Remove the scanner unit with the plastic cover by lifting it up from the bottom portion of the printer.
    • Be careful with the paper tray and make sure it is evenly lifted through the rectangular hole in the plastic tray
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Raymond
42 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 18-38, Regan Winter 2013 Mitglied von Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Mitglieder
4 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 910
