Einleitung
Is your Lexus keyfob buttons out of battery? Use this guide to learn how to open the keyfob and swap out the battery. The only tool you will need in this guide is your keyfob!
Was du brauchst
With the button side facing you, pull the metal latch down towards you to pull out the key.
With the exposed corner facing you, place the metal key into the slot.
Turn the key sideways to open the keyfob.
Fast fertig!
Abschluss
