Einleitung
Over time, O-rings will wear out and your pump will begin to develop leaks. Some indicators of worn O-rings are low pump resistance while inflating tires, abnormal hissing when pumping, or a pump plunger jam.
Was du brauchst
Lift the rubber ABS hose cover to expose the ABS hose fitting.
Turn the silver ABS hose fitting counter-clockwise until it fully unthreads.
Remove the ABS hose from the pump.
Pull the ABS hose cover off the pump by pulling it straight away from the pump.
Flip the pump around and unplug the rubber cover on the outlet side of the pump.
Remove the outlet cover the same way as the ABS hose cover.
Use channel locks or pliers to grip the silver cap and turn it counter-clockwise until it is loose.
Continue turning the silver cap counter-clockwise by hand until it fully unthreads.
Pull the pump plunger out of the pump body.
Use channel locks or pliers to grip the pump outlet cap and turn it counter-clockwise until it is loose.
Continue turning the outlet cap counter-clockwise by hand until it fully unthreads.
Remove the pump outlet cap.
Use your finger to remove the bump-stop O-ring from below the pump's outlet cap threads.
Place a new bump stop O-ring into the pump.
The O-ring can be inserted into the other side of the pump body. As long as it is straight, the pump plunger will push it down to it's proper place.
Replace the 3 O-rings on the ABS hose. Use a small flathead screwdriver to help pry the old O-rings off and stretch the new O-rings on.
Replace the two O-rings on the pump plunger using the same method as the previous O-rings.
Replace the outlet cap O-ring using the same method as the previous O-rings.
Re-assemble the pump by using these instructions in reverse.
Eine weitere Person hat diese Anleitung absolviert.
