Einleitung
Is your LifePrint 2x3 not holding a charge? The issue at hand may be that the battery is faulty and not working. If your device is failing to hold a charge, the battery may need to be replaced. Consider using this guide to replace the faulty battery in your device.
Was du brauchst
Orient the LifePrint 2x3 so that the top of the device is facing upwards. Slide the top cover toward the far side of the device and remove it.
Remove the six 5.24 mm screws located around the edges of the device using a Phillips #00 Screwdriver.
Flip the LifePrint 2x3 upside down. Using a plastic opening pick, separate the bottom cover from the device and remove it.
Using the angled tweezers grip the sides of the connector and slowly rock it side to side to remove. If the connector is not disconnecting, try using the spudger but be careful not to damage the motherboard.
Once disconnected, remove the old battery.
6 Kommentare
Hi. Where can you buy the replacement battery? Thank you.
Hi can I know where I can buy the battery?
I found it hard to buy the battery, you can buy 2 small Li ion batteries of 3.7V, and put them in series, that way you get a battery you can use
Is something homemade but it works. Reutilize the 5P with the NTC, and connect the NTC to ground if your 3V doesn't have one.
Btw original characteristics are
- 7.4V nominal
- 8.4V charge
- 500mAh
- 3.7Wh
https://es.aliexpress.com/item/100500537...
