Zum Hauptinhalt wechseln
LifePrint 3x4.5 Battery Replacement
Was du brauchst
  1. LifePrint 3x4.5 Battery Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
  2. LifePrint 3x4.5 Battery Replacement, Inner Cover: Schritt 2, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove three 4mm Phillips #0 screws connecting the metal shield covering the battery.
    • Slide out the white power connector with two red wires, two black wires, and one yellow wire from the terminal connected to the circuit board.
    • Apply pressure gently and slowly from underneath the battery from the plastic.
  4. LifePrint 3x4.5 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the printer.
Abschluss
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S1-G2, Barthe Fall 2019
UMASSD-BARTHE-F19S1G2
3 Mitglieder
6 Anleitungen geschrieben
3 Kommentare
Où trouver la batterie ? Quelles caractéristiques ?
Baphi - Antwort
C'est parfait mais la batterie EVE P0867 7.4V 900mAh est introuvable... Avez vous un lien ?
Merci
Laurent Villiger - Antwort
Thank you for instructions. Do you know where to buy the 7.4V 900mAh battery? I can't seem to find one.....thanks!
Julie - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 31
Letzte 30 Tage: 60
Insgesamt: 1,142
