Was du brauchst
Schritt 1 Power off
Achtung: Die Schritte 1-5 stammen von einer Anleitung, die derzeit bearbeitet wird.
Power off the tablet by holding down the power button (on the bottom) and tapping "Power off" on screen, then wait 10-15 seconds for the underlying Android system to shut down.
Unscrew the two Torx T2 screws surrounding the USB port.
Image needed: showing just the bottom in order to highlight screws in blue
Use the opening tool to pry at the lip in between the bezel and rear cover,
then slide in your opening pick with the flat end,
and slide it around to undo these clips.
(Note to self: Try opening the side using opening tools)
After releasing the clips, lift the front bezel out.
Lift up part of the tape covering the frontlight connector.
Using the flat end of your spudger, disconnect the display.
Peel the tape the rest of the way
Using the pointed end of your spudger, disconnect the frontlight.
Remove these screws using your J00 screwdriver (or a PH00 screwdriver if you don't have one).
Remove these screws using your PH00 screwdriver.
You should be able to poke the screwdriver through it.
