Zum Hauptinhalt wechseln
Likebook Muses Rear Cover Replacement
Was du brauchst
  1. Likebook Muses Rear Cover Replacement, Power off: Schritt 1, Bild 1 von 1
    • Power off the tablet by holding down the power button (on the bottom) and tapping "Power off" on screen, then wait 10-15 seconds for the underlying Android system to shut down.
  2. Likebook Muses Rear Cover Replacement, Rear Cover: Schritt 2, Bild 1 von 1
    • Unscrew the two Torx T2 screws surrounding the USB port.
    • Image needed: showing just the bottom in order to highlight screws in blue
  3. Likebook Muses Rear Cover Replacement: Schritt 3, Bild 1 von 3 Likebook Muses Rear Cover Replacement: Schritt 3, Bild 2 von 3 Likebook Muses Rear Cover Replacement: Schritt 3, Bild 3 von 3
    • Use the opening tool to pry at the lip in between the bezel and rear cover,
    • then slide in your opening pick with the flat end,
    • and slide it around to undo these clips.
  4. Likebook Muses Rear Cover Replacement: Schritt 4, Bild 1 von 3 Likebook Muses Rear Cover Replacement: Schritt 4, Bild 2 von 3 Likebook Muses Rear Cover Replacement: Schritt 4, Bild 3 von 3
    • (Note to self: Try opening the side using opening tools)
    • After releasing the clips, lift the front bezel out.
    • The extension piece for the power button can fall out. Don't lose this!
  5. Likebook Muses Rear Cover Replacement: Schritt 5, Bild 1 von 1
    • The rear cover has been removed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kevin Bhasi
1.262 Reputation
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 126
