Einleitung
Replace the rear cover on your Likebook Muses (Boyue T78D).
This guide does not cover replacing the aluminium panel separately.
Flagged as “In Progress” as the image in step 3 needs to be replaced with one depicting an intact display.
Was du brauchst
Power off the tablet by holding down the power button (on the bottom) and tapping "Power off" on screen, then wait 10-15 seconds for the underlying Android system to shut down.
Unscrew the two Torx T2 screws surrounding the USB port.
Image needed: showing just the bottom in order to highlight screws in blue
Use the opening tool to pry at the lip in between the bezel and rear cover,
then slide in your opening pick with the flat end,
and slide it around to undo these clips.
(Note to self: Try opening the side using opening tools)
After releasing the clips, lift the front bezel out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
