Zum Hauptinhalt wechseln
Linksys WAP54g Antennas Replacement
  1. Linksys WAP54g Antennas Replacement, Antennas: Schritt 1, Bild 1 von 2 Linksys WAP54g Antennas Replacement, Antennas: Schritt 1, Bild 2 von 2
    • Make sure the antennas are in a straight position, not bent, to remove the black casing.
    • Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
  2. Linksys WAP54g Antennas Replacement: Schritt 2, Bild 1 von 1
    • Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
  3. Linksys WAP54g Antennas Replacement: Schritt 3, Bild 1 von 1
    • Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
  4. Linksys WAP54g Antennas Replacement: Schritt 4, Bild 1 von 1
    • Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
  5. Linksys WAP54g Antennas Replacement: Schritt 5, Bild 1 von 1
    • Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
    • Repeat these steps for other antenna.
Abschluss
After the repairs are made the device should working.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Derek Myers
288 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 21-21, Maness Fall 2011 Mitglied von Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 2,562
