Einleitung
You will start by isolating the motherboard and then continue to make the suggested repairs by soldering.
Was du brauchst
Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of Installing the Antennas Guide: Linksys WAP54g Antennas Replacement
Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
Unscrew the two screws that connect the motherboard to the bottom casing.
Using a soldering iron, desolder the LED lights from the bottom of the logic board.
For help with soldering or desoldering refer to ifixit's soldering guide: Wie man Lötverbindungen herstellt und entlötet
Place new LED lights through holes created by desoldering and removing old lights.
Solder the lights onto the bottom of the board to solidify the connection and make electrical contact.
Follow the Installing the Casing guide in reverse to re-assemble your device.
Once the soldering is complete, the device should work and the LED lights should light up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
