Zum Hauptinhalt wechseln
Linksys WRT54GS v2 Front Case Replacement
Was du brauchst
  1. Linksys WRT54GS v2 Front Case Replacement, Front Case: Schritt 1, Bild 1 von 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Front Case Replacement: Schritt 2, Bild 1 von 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Front Case Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Front Case Replacement: Schritt 4, Bild 1 von 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Allian Roman
276 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-4, Regan Fall 2011 Mitglied von Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 11
Insgesamt: 1,075
