Zum Hauptinhalt wechseln
Linsay Model F-7HD2CORE Battery Replacement
Was du brauchst
  1. Linsay Model F-7HD2CORE Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Carefully insert your plastic opening tool in between the white and black sections of your device.
    • Gently pry the top screen portion from the base of the tablet.
    • Your tablet should now look like the third image.
  2. Linsay Model F-7HD2CORE Battery Replacement: Schritt 2, Bild 1 von 2 Linsay Model F-7HD2CORE Battery Replacement: Schritt 2, Bild 2 von 2
    • To completely remove the base from the top of the tablet, peel the microphone from the back.
  3. Linsay Model F-7HD2CORE Battery Replacement: Schritt 3, Bild 1 von 2 Linsay Model F-7HD2CORE Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the two pieces of tape holding the battery in place by gently peeling it off.
  4. Linsay Model F-7HD2CORE Battery Replacement: Schritt 4, Bild 1 von 1
    • Using the spudger, carefully peel the battery off of the tablet panel.
    • Tape of the back of the battery will be very strong, pull gently!
    • The metal exterior of the battery can be quite pliable. Use caution when removing the battery from the tablet.
  5. Linsay Model F-7HD2CORE Battery Replacement: Schritt 5, Bild 1 von 1
    • To remove the battery, completely desolder the wires connected to the circuit board.
    • To reattach the new battery, you must solder the wires back on.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Penn State, Team 1-5, Kaschak Winter 2015 Mitglied von Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,434
