Einleitung
After determining that your battery is permanently damaged or broken, you can replace it with a new one.
Was du brauchst
Carefully insert your plastic opening tool in between the white and black sections of your device.
Gently pry the top screen portion from the base of the tablet.
Your tablet should now look like the third image.
To completely remove the base from the top of the tablet, peel the microphone from the back.
Remove the two pieces of tape holding the battery in place by gently peeling it off.
To remove the battery, completely desolder the wires connected to the circuit board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
