Zum Hauptinhalt wechseln
Linsay Model F-7HD2CORE Screen Replacement
Was du brauchst
  1. Linsay Model F-7HD2CORE Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Linsay Model F-7HD2CORE Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Linsay Model F-7HD2CORE Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Insert your plastic opening tool in between the black and white portions of your device.
    • Gently pry the top screen from the base of the tablet.
    • Your tablet should now look like the third photo.
  2. Linsay Model F-7HD2CORE Screen Replacement: Schritt 2, Bild 1 von 2 Linsay Model F-7HD2CORE Screen Replacement: Schritt 2, Bild 2 von 2
    • Peel the microphone from the back of the device.
  3. Linsay Model F-7HD2CORE Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the tape from the indicated copper strip.
  4. Linsay Model F-7HD2CORE Screen Replacement: Schritt 4, Bild 1 von 2 Linsay Model F-7HD2CORE Screen Replacement: Schritt 4, Bild 2 von 2
    • Use your 00 phillips head screwdriver to remove the three 4mm phillips screws circled in red.
  5. Linsay Model F-7HD2CORE Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the soldered portion of the circuit board on the screen.
    • You will need a soldering kit to reattach this part.
  6. Linsay Model F-7HD2CORE Screen Replacement: Schritt 6, Bild 1 von 2 Linsay Model F-7HD2CORE Screen Replacement: Schritt 6, Bild 2 von 2
    • Use the blunt end of the spudger to remove the circuit panel and battery from the glass screen portion of the device.
    • There will be several small hooks holding the screen onto the back panel.
  7. Linsay Model F-7HD2CORE Screen Replacement: Schritt 7, Bild 1 von 2 Linsay Model F-7HD2CORE Screen Replacement: Schritt 7, Bild 2 von 2
    • Gently pull the two pieces of the tablet apart.
    • Your tablet should now look like image two.
    • You are now ready to attach your new screen!
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Penn State, Team 1-5, Kaschak Winter 2015 Mitglied von Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
Excellent work!
Glen Lind - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,307
