Einleitung
If you just can't find out what is wrong with your disco ball, you will probably need to open it to troubleshoot it. This guide will walk you through the steps to do that.
Was du brauchst
Turn the device over so that the base is on top.
Peel off the piece of metal that is glued to hold the two halves of the base together.
Fast fertig!
Abschluss
