Zum Hauptinhalt wechseln
Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement
Was du brauchst
  1. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: Schritt 1, Bild 1 von 1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: Schritt 2, Bild 1 von 3 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: Schritt 2, Bild 2 von 3 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: Schritt 2, Bild 3 von 3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: Schritt 3, Bild 1 von 1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: Schritt 4, Bild 1 von 2 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: Schritt 4, Bild 2 von 2
    • Unscrew the burnt-out light bulb with a counter-clockwise twist.
    • Do not apply too much pressure when unscrewing light bulb, as the light bulb may break.
Ziellinie
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 17-3, Forte Winter 2014 Mitglied von Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Mitglieder
7 Anleitungen geschrieben
4 Kommentare
Great! Wasn't sure how to remove the base. Thank you!
derigo1957 - Antwort
Saved me a headache. Couldn't figure out how to remove base. Thanks!
mccullough1251 - Antwort
Helpful guide. Thank you.
In case there is any confusion, all you have to do is push in that tab on one side and lift. No twisting necessary. Also, the other side will come off.
jgprus - Antwort
Thank you so much! I was afraid of breaking the globe. That really helped because I couldn’t figure out how to disconnect the base.
Melissa Fleming - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 27
Letzte 30 Tage: 82
Insgesamt: 15,452
