Einleitung
Has your disco ball stopped rotating and turned into a weird, multi-colored lamp? Use this guide to avoid the party-foul and get that ball spinning!
Was du brauchst
Turn the device over so that the base is on top.
Peel off the piece of metal that is glued to hold the two halves of the base together.
Use a pair of tweezers to crush the sides of the wirenuts.
Pull all of the wires out of the wirenuts.
To reassemble your device, follow these instructions in reverse order, starting from step five.
2 weitere Personen haben diese Anleitung absolviert.
