Einleitung
Remove the top cover of the optical drive to access the internals and replace any malfunctioning components.
Was du brauchst
Insert an open paper clip into the small hole on the left side of the faceplate.
After the tray opens, extend it fully.
Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
2 weitere Personen haben diese Anleitung absolviert.
