Zum Hauptinhalt wechseln
Einleitung
If the disc tray has fallen out of alignment or has broken, you will need to replace it.
  1. Insert an open paper clip into the small hole on the left side of the faceplate. After the tray opens, extend it fully.
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Pull the faceplate away from the main chassis.
    • Pull the faceplate away from the main chassis.
  4. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  5. Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  6. Lift the top and bottom chassis straight up in order to remove them. Lift the top and bottom chassis straight up in order to remove them.
    • Lift the top and bottom chassis straight up in order to remove them.
  7. Extend the tray fully. Push the tab on the right side to the left. Push the tab on the left side to the left.
    • Extend the tray fully.
    • Push the tab on the right side to the left.
    • Push the tab on the left side to the left.
    • Remove the tray carefully.
  8. Guide the replacement tray under the beige tabs. Make sure the grey piece is slid to the right, so the grey nob is under the right-hand groove of the tray. Check to see that the tray extends and closes smoothly.
    • Guide the replacement tray under the beige tabs.
    • Make sure the grey piece is slid to the right, so the grey nob is under the right-hand groove of the tray.
    • Check to see that the tray extends and closes smoothly.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
James Biggs
596 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 6-5, Regan Fall 2011 Mitglied von Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 3,511
