Zum Hauptinhalt wechseln
Lite-On iHAS324 Face Plate Replacement
Was du brauchst
  1. Lite-On iHAS324 Face Plate Replacement, Chassis: Schritt 1, Bild 1 von 2 Lite-On iHAS324 Face Plate Replacement, Chassis: Schritt 1, Bild 2 von 2
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Face Plate Replacement: Schritt 2, Bild 1 von 3 Lite-On iHAS324 Face Plate Replacement: Schritt 2, Bild 2 von 3 Lite-On iHAS324 Face Plate Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Face Plate Replacement: Schritt 3, Bild 1 von 1
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Face Plate Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Face Plate Replacement: Schritt 5, Bild 1 von 1
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Face Plate Replacement: Schritt 6, Bild 1 von 1
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Face Plate Replacement, Disc Tray: Schritt 7, Bild 1 von 2 Lite-On iHAS324 Face Plate Replacement, Disc Tray: Schritt 7, Bild 2 von 2
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
  8. Lite-On iHAS324 Face Plate Replacement, Face Plate: Schritt 8, Bild 1 von 1
    • Slide the faceplate off the disc tray.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Baylor, Team 5-9, Williams Spring 2015 Mitglied von Baylor, Team 5-9, Williams Spring 2015
BU-WILLIAMS-S15S5G9
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 485
