Einleitung
Use this guide to remove and replace the bearings and blade shaft in the Little Wonder 4 HP Honda Pro Edger 62320001 Rev B.
Was du brauchst
Lift the belt slackener lever to take tensions off the belts.
Secure it in the slackened position.
Use a 3/8 inch socket and ratchet to remove the two bolts securing the belt guard.
Slide the belt guard forward and away from the belt pulley.
Slide the guard to the side, away from the wheels to expose the belts.
Slide the outer belt across the pulley, toward the wheel, and off of the pulley.
Slide both belts away from the engine and off of the pulleys.
Remove both belts.
Use a 1/2 inch socket to remove the belt guard bolt.
Move the blade adjusting lever up into the lowered position to lower the blade.
Use a 3/4 inch socket and ratchet to remove the nut securing the blade.
Brace the left side of the blade against the ground in order to loosen the nut. Brace the right side of the blade against the ground for tightening.
Remove the outer blade washer.
Remove the blade
Remove the inner blade washer.
Use a 9/16 inch socket and ratchet to remove the bolt securing the wheels.
Use a 5/32 hex key to loosen the two set screws securing the belt pulley.
Use snap ring pliers to remove the snap ring on the side of the blade shaft closest to the engine.
Use a mallet to tap the side of the blade shaft farthest from the engine until you can slide the blade shaft out.
Remove the blade shaft.
Use a punch, bearing puller, or a large socket on the side of the cutter head closest to the engine to tap out the second bearing.
Remove the bearing.
Use a mallet to install the bearing closest to the engine first.
Reinstall the snap ring on the blade shaft.
Tap the blade shaft back into the cutter head, starting from the side closest to the engine.
Reinstall the old key in the new shaft. If your shaft came with a new key, use the old key for this process, then replace it with the new key.
Set the second new bearing in the side of the cutter head farthest from the engine.
Reinstall the blade and both washers.
Use an adjustable wrench to hold the shaft in place. At the same time, use a 3/4 inch socket and a ratchet to tighten the blade nut and push the bearing into the cutter head.
