Einleitung
Use this guide to remove or replace the blade on a Little Wonder 4 HP Honda Pro Edger 62320001 Rev B.
Was du brauchst
Use a 3/4 inch socket and ratchet to remove the nut securing the blade.
Brace the left side of the blade against the ground in order to loosen the nut. Brace the right side of the blade against the ground for tightening.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
