Einleitung
Use this guide to remove or replace the V Belts on a Little Wonder 4 HP Honda Pro Edger 62320001 Rev B.
Was du brauchst
Lift the belt slackener lever to take tensions off the belts.
Secure it in the slackened position.
Use a 3/8 inch socket and ratchet to remove the two bolts securing the belt guard.
Slide the belt guard forward and away from the belt pulley.
Slide the guard to the side, away from the wheels to expose the belts.
Slide the outer belt across the pulley, toward the wheel, and off of the pulley.
Slide both belts away from the engine and off of the pulleys.
Remove both belts.
