Einleitung
Follow this guide to replace the fan on a Little Wonder GX270 blower with Honda engine.
Was du brauchst
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2 inch wrench to remove the intake guard bolt behind the front wheel.
Use an impact wrench to remove the 5/8 inch bolt securing the fan blade to the spindle.
Fast fertig!
Abschluss
