Werkzeuge
Ersatzteile
On the bottom side of the webcam, remove the stickers from both sides
Remove the lens' crystal cover.
Remove the four Phillips screws from the metal support.
Remove the microphone's rubbers (one from each side).
Carefully remove the plastic support's base.
Loosen the three screws that secure the electronic circuit.
Release the clips that secure the cable holder. Pull that cable holder, out of the camera.
The problem was the broken cable on the back of the camera. I've cut the faulty part and redid the connections by welding them and insulated them with heat shrinking tubes.
Repaired cable and attached to the camera. Coated it with some crepe tape. Camera tested: OK!
Assemble the webcam following the steps in a reverse order.
14 weitere Nutzer haben diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer*innen:
100%
Diese Übersetzer*innen helfen uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
15 Kommentare
Excellent! Helped me figure out how to get the base off to mount it to an ikea worklamp as a hacky boom.
thanks for an excellent guide . I am now more positive that it is something I can perform now. Many thanks
im having trouble releasing the 4 screws on step 3!!! the screw driver keeps slipping and i’ve tried a few and another webcam…
Dojo, Use the correct screw driver. So easy to unscrew.
If you have damaged the screw head, you can use pliers. You will need to replace the damaged screws.
They’re quite tight screws on the ones I’ve worked on . Super, super soft metal too, very easy to strip out.
