Zum Hauptinhalt wechseln
Logitech Circle Ribbon Cable Replacement
Was du brauchst
  1. Logitech Circle Ribbon Cable Replacement, Ribbon Cable: Schritt 1, Bild 1 von 2 Logitech Circle Ribbon Cable Replacement, Ribbon Cable: Schritt 1, Bild 2 von 2
    • Wedge the plastic opening tool under the black circle lens and gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Ribbon Cable Replacement: Schritt 2, Bild 1 von 2 Logitech Circle Ribbon Cable Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Ribbon Cable Replacement: Schritt 3, Bild 1 von 2 Logitech Circle Ribbon Cable Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Ribbon Cable Replacement: Schritt 4, Bild 1 von 2 Logitech Circle Ribbon Cable Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Ribbon Cable Replacement: Schritt 5, Bild 1 von 2 Logitech Circle Ribbon Cable Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Ribbon Cable Replacement: Schritt 6, Bild 1 von 2 Logitech Circle Ribbon Cable Replacement: Schritt 6, Bild 2 von 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Ribbon Cable Replacement: Schritt 7, Bild 1 von 3 Logitech Circle Ribbon Cable Replacement: Schritt 7, Bild 2 von 3 Logitech Circle Ribbon Cable Replacement: Schritt 7, Bild 3 von 3
    • Once the old ribbon cable has been detached from the lens/battery bundle it's time to release the other side from the base.
    • Locate the screws holding the base together by feeling for the soft spots underneath the manufacturer's sticker. Punch through with your screwdriver and remove the three 3mm Phillips #0 screws.
    • The two pieces of the base can now be easily pulled apart.
  8. Logitech Circle Ribbon Cable Replacement: Schritt 8, Bild 1 von 2 Logitech Circle Ribbon Cable Replacement: Schritt 8, Bild 2 von 2
    • Gently pull the ribbon cable loose from its connection to the base.
  9. Logitech Circle Ribbon Cable Replacement: Schritt 9, Bild 1 von 2 Logitech Circle Ribbon Cable Replacement: Schritt 9, Bild 2 von 2
    • Slide the push pin holding the plastic connector/ribbon cable in place out on both sides.
  10. Logitech Circle Ribbon Cable Replacement: Schritt 10, Bild 1 von 1
    • Remove the black plastic connector and the two springs from the base of the device.
  11. Logitech Circle Ribbon Cable Replacement: Schritt 11, Bild 1 von 1
    • Reach inside the circle and pull the ribbon cable free from the device.
Abschluss
Haley Williams
112 Reputation
1 Anleitung geschrieben
University of Maine, Team S1-G4, Diaz Fall 2017 Mitglied von University of Maine, Team S1-G4, Diaz Fall 2017
UMAINE-DIAZ-F17S1G4
3 Mitglieder
7 Anleitungen geschrieben
6 Kommentare
where can I buy such a cable?
kersop@gmail.com
Nico Kersop - Antwort
The cable I received from China is not the right one. Where do you buy the correct one?
Helen - Antwort
Can you advise where to buy the correct cable?
Michele Ingratta - Antwort
I have cable has beark off. I need that cable.
Where can I find
Alican Döşlü - Antwort
i also need that cable
l_samin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 1,983
