Zum Hauptinhalt wechseln
Logitech Circle Speaker Replacement
Was du brauchst
  1. Logitech Circle Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 Logitech Circle Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Wedge the plastic opening tool under the black circle lens to gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Speaker Replacement: Schritt 3, Bild 1 von 2 Logitech Circle Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Speaker Replacement: Schritt 4, Bild 1 von 2 Logitech Circle Speaker Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Speaker Replacement: Schritt 5, Bild 1 von 2 Logitech Circle Speaker Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Speaker Replacement: Schritt 6, Bild 1 von 2 Logitech Circle Speaker Replacement: Schritt 6, Bild 2 von 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Speaker Replacement: Schritt 7, Bild 1 von 1
    • Locate the speaker attachment, and carefully remove the speaker plug from the lens.
  8. Logitech Circle Speaker Replacement: Schritt 8, Bild 1 von 1
    • Remove the speaker using a plastic opening tool. The battery is attached with glue, so use gentle prying motions to remove speaker.
Abschluss
Emma Cochran
110 Reputation
1 Anleitung geschrieben
University of Maine, Team S1-G4, Diaz Fall 2017 Mitglied von University of Maine, Team S1-G4, Diaz Fall 2017
UMAINE-DIAZ-F17S1G4
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 22
Insgesamt: 366
