Zum Hauptinhalt wechseln
Logitech Dual Action Triggers Repair
Was du brauchst
  1. Logitech Dual Action Triggers Repair, Logitech Dual Action Triggers Repair: Schritt 1, Bild 1 von 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in red.
    Frag FixBot
  2. Logitech Dual Action Triggers Repair: Schritt 2, Bild 1 von 2 Logitech Dual Action Triggers Repair: Schritt 2, Bild 2 von 2
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    Frag FixBot
  3. Logitech Dual Action Triggers Repair: Schritt 3, Bild 1 von 1
    • There should be 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 oval shaped buttons.
    Frag FixBot
  4. Logitech Dual Action Triggers Repair: Schritt 4, Bild 1 von 3 Logitech Dual Action Triggers Repair: Schritt 4, Bild 2 von 3 Logitech Dual Action Triggers Repair: Schritt 4, Bild 3 von 3
    • In the center of the controller, pull upwards on the USB cord.
    • Be careful not to pull hard enough to yank the wires connecting to the logic board.
    • With the wire out of the way, remove the screw it exposed. This will disconnect the logic board from the controller.
    Frag FixBot
  5. Logitech Dual Action Triggers Repair: Schritt 5, Bild 1 von 3 Logitech Dual Action Triggers Repair: Schritt 5, Bild 2 von 3 Logitech Dual Action Triggers Repair: Schritt 5, Bild 3 von 3
    • To remove the triggers, push upwards from the back on them.
    • Once far enough, detach the logic board from the back cover piece and the triggers.
    Frag FixBot
  6. Logitech Dual Action Triggers Repair: Schritt 6, Bild 1 von 2 Logitech Dual Action Triggers Repair: Schritt 6, Bild 2 von 2
    • If the wire is unplugged solely from the logic board, you can fasten it back into its place.
    • Look at the second picture to see where the wires go.
    Frag FixBot
  7. Logitech Dual Action Triggers Repair: Schritt 7, Bild 1 von 3 Logitech Dual Action Triggers Repair: Schritt 7, Bild 2 von 3 Logitech Dual Action Triggers Repair: Schritt 7, Bild 3 von 3
    • Unscrew the screw on the trigger to remove the back cover.
    • Once removed, carefully pull the back cover off.
    Frag FixBot
  8. Logitech Dual Action Triggers Repair: Schritt 8, Bild 1 von 1
    • The 3 wires are soldered into the 3 spots circled on the picture.
    • You can now fasten the wire into the right spot on the trigger piece.
    Frag FixBot
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 7-4, Remmell Winter 2015 Mitglied von USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Mitglieder
5 Anleitungen geschrieben
4 Kommentare zur Anleitung
Hi dear, can you say me the order of colours in the USB cable? I think green, white, red, black thin and black thick. Is It correct?
Cas - Antwort Teilen
Where can I get conductive pads for this?
Ginga - Antwort Teilen
RADO rakotonatoandro - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 138
Insgesamt: 12,014
