Zum Hauptinhalt wechseln
Logitech Dual Action disassembly
Was du brauchst
  1. Logitech Dual Action disassembly, Taking out the screws: Schritt 1, Bild 1 von 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
    Frag FixBot
    Kommentar hinzufügen
  2. Logitech Dual Action disassembly, Opening the controller: Schritt 2, Bild 1 von 3 Logitech Dual Action disassembly, Opening the controller: Schritt 2, Bild 2 von 3 Logitech Dual Action disassembly, Opening the controller: Schritt 2, Bild 3 von 3
    • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
    • Separate the top and bottom casing.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
    Frag FixBot
  3. Logitech Dual Action disassembly, Cleaning the buttons: Schritt 3, Bild 1 von 1
    • Turn the top casing of the controller over to remove all the buttons.
    • Wipe each individual button with a piece of cloth and rubbing alcohol.
    Frag FixBot
Ziellinie
12 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 7-4, Remmell Winter 2015 Mitglied von USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 130
Insgesamt: 8,444
