Einleitung
After extended use certain parts may require cleaning or replacement. This guide will assist you in safely disassembling the base portion of the joystick. This will require to have to handle already disassembled.
Was du brauchst
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
Remove the two 10mm Phillips #1 screws.
Pull apart the joystick chassis by hand.
Release this clip located underneath the hand rest
Remove the eight 10mm Phillips #1 screws from the bottom.
Flip the joystick upright.
Lift up the sliver base cover and feed the loose circuit board through.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
