Zum Hauptinhalt wechseln
Logitech Extreme 3D Pro Disassembly of the base
Was du brauchst
  1. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the handle: Schritt 1, Bild 1 von 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the base: Schritt 2, Bild 1 von 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the base: Schritt 3, Bild 1 von 2 Logitech Extreme 3D Pro Disassembly of the base: Schritt 3, Bild 2 von 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the base: Schritt 4, Bild 1 von 1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Disassembly of the base: Schritt 5, Bild 1 von 3 Logitech Extreme 3D Pro Disassembly of the base: Schritt 5, Bild 2 von 3 Logitech Extreme 3D Pro Disassembly of the base: Schritt 5, Bild 3 von 3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Emanuel Canela
1.297 Reputation
7 Anleitungen geschrieben
USF Tampa, Team S7-G1, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Mitglieder
Ein Kommentar
And you didn’t even finish the repair. Thanks for nothing. :(
Jesse James - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 62
Insgesamt: 3,705
